What is this gear?
YotaBota
Mike
When I was surfing around I found this on lathes.uk about VDF lathes. The gear just below the spindle appears adjustable in what looks like either seconds or minutes. Anyone know the purpose of this gear?
Yes, it is the main drive gear of the feed/threading gearbox. On can move the gear in relation to its drive shaft to, for example, create multi start threads.
This feature could also be used to cut multi fluted parts.
Say you start with the gear at 0* and thread 8 TPI. After that thread is finished, move the gear to the 180* position and thread again at 8 TPI. The result will be a 16 TPI, two start thread. If you only moved 90* and did this four times, you’d end up with a 32 TPI, 4 start thread.
This can be done with just about any lathe as long as the gear’s # of teeth is divisible by the number of thread starts you try to cut. One would have to mark some references on the gears to get it right, but it can be done. Leave the feed in the headstock engaged to do this and advance the gear train by the required # of teeth and remount the gear.
The other way to cut multi-start threads is to use the compound parallel to the Z-axis and advance/retract it the correct distance for the TPI you are cutting. All the threading is done by plunging with the cross slide in that operation.
Steve Summer’s Hendey Lathe has a lever to disengage/engage the feed gear to produce multi start threads. He has a video where he explains this feature.
Thank you sir, so any lathe can index to the limit of the gear that engages the gearbox to the spindle. I'll put this info in my toolbox.
I think so. It’s just not as convenient with the average machine vs a VDF or a Hendey (there are probably others with this feature like some Russian ones I have seen - can’t find the video right now)
I built an indexer(ish) using a 60 toothsaw blade on an arbor fit to the spindle and a pointer attached on the headstock. It worked but it wasn't convenient either.
I needed to evenly space 10 reference lines on a shaft, it worked but as robinhood says,, it wasn't convenient.
