We’ve got 2 of them here.I think I got mine at my local Princess Auto in Ottawa. I think there's a Princess Auto in Calgary
I'll take a look at it tomorrow and take a pic. I believe it states ISO68 not specifically Way Oil.I don't think I'd trust PA to have good way oil unless it's in a Brand Name jug or pail and clearly labelled as way oil.
You guys that are running Shell Tonna, have you ever run it alongside, or switched from EEZ brand (through KBC). My only beef with EEZ is I'm convinced it does some staining over time, particularly which has a more open grain vs hardened bedways. The tan color brown is removable with varsol & soft scrubby but it just bugs me a bit.
I was also thinking cutting oil might be a culprit in & around the the chuck area. I see some stain on my mill vise & cutting tools if I don't give them a wipe & they sit there. Not even sure if they contain Sulphur but they do stain. However, I'm seeing this tan stain in other lubrication areas that never see cutting oil like the tailstock, shift levers, far end of power shafts.... Its not the end of the world but just more of an irritant. Might have to try some other brand. I've had this EEZ for many years but cant imagine it goes bad.However, I like to use a high sulphur cutting oil on steel and that stuff almost stains on contact. Could that be the source of your stains?
