Unimat - taper pins
Johnwa
I need to turn a couple of taper pins for shear pins. The pins are about 1.25” long with a taper of ¼”/ft. On a unimat you can rotate the headstock to cut a taper. Here’s a couple of pics cutting one in steel. The actual shear pins will be brass. The scarf comes off looking like steel wool.
Why do I have this feeling the next time we see a picture of Little Greeny, you will have overclocked it with micro-VFD, stepper motors on all the lead screws... and motion control under the headstock so it can power rotate too for good measure! 🙂
