SilverSlugger
New Member
What kind of drill do I need to make holes in an aluminum beverage can?
Maybe not recommended for home shop use?This has worked well for me in the pastView attachment 48503
Take me home, country roadsMaybe not recommended for home shop use?
Use the sub-sonic ones.Maybe not recommended for home shop use?
top of the can mainly, but a couple of small 3/16 holes on top of the sides as well.What calibre, uh, diameter hole are you trying to produce? Top of the can? Bottom? Sides?
From a more serious perspective, trying to make tidy holes in the side of an aluminum can would be pretty awkward. The step drill suggestion is a good one, but it’ll still be hard to keep the can from distorting. Really top notch options would be laser cutting, or maybe edm?
If I had to produce a decent sized hole, without caving the side in, I might look at freezing the can so it was supported. It’d puff up from the expansion, but if you can open it first and let some fluid out, that’d fix that.
what about a hole saw with a cobalt drill?Step drill
