Johnwa
Someone got a deal. It sold for $976
bids.regalauctions.com
Regal Auctions Ltd.
That motor has to be replaceable with a 220/440v 3 phase motor, no?Meh I looked at it.
I bid on it but did not feel I want to go for more.
The machine has a two speed 380v motor - so replacing it is out of question. It should run fine at 440v at 60Hz.
DRO is broken.
I considered fixing it a bit and trying to sell for $2000 with maybe initial list of 2500. It would be a hard sell given the voltage. I have single phase transformer needed but not 3ph one.
Just curious. Is a 380V motor of that era & bolt pattern miles more difficult to retrofit a suitable power 3-phase motor for retrofit? Need to add VFD of course, but I mean just the motor aspect itself? ps - the blue handle makes me very suspicious LOL
I agree. Not really that hard to make a motor adapter plate. In fact even possible to make a double plate that positions the business end of the motor in the same place. Biggest issue is often the length and diameter of the motor shaft.
No. Its a TWO SPEED motor not two voltage motor.
It switches from being a two pole to four pole motor and has two speed ranges - in EU its 1200 and 2500 rpm.
Its similar concept to Swidish drill press.
So next to impossible to replace apples for apples.
