slow-poke
Based on this thread... https://canadianhobbymetalworkers.com/threads/test-bar.12370/page-3
I imaging this question should invoke a few opinions ;-) I realize I'm splitting hairs here, but I'm here to learn.
In the previous thread I mentioned a rectangular straight edge and it seemed that most responders wanted to know what the heck do you need this straight edge for, well one example would be tramming a vise. Yes I can set up a sensitive lever dial indicator and run it the width of the vise (which is only 4" or 5") for the two that I use. So now imagine I tram that 4" vise and it's pretty close say a few tenths. If I had a really good straight edge so I could check it say 18" further away, that few tenths might be 0.002"? or more who knows?
Furthermore after tramming the vise to somewhere in the tenth's, if I grasp both ends of the table and twist it (depending on how tight the Gib's are), I can move that indicator perhaps by more than the tram error just from the slop in the Gib's. So there needs to be a compromise between:
- tight/loose Gib's
- easy table movement
- accuracy
- wear
My (Taiwan manufactured) 8x30 knee mill is old, used, not scraped so I don't really have a sense of what can be expected from a machine like this?
So for anyone that has taken the time to measure the error on their or preferable better quality work machines, I'm curious what you have found, I'm also curious how accurate a really good mill like a Mazak is in comparison?
Do I need this type of accuracy for what I'm doing, probably not most of the time, but I would prefer to at least have a clue as to how good or bad my machine is and what I can expect it to do if I do need to make something to a tight tolerance.
- tight/loose Gib's
- accuracy
- wear
