Hi,
New user here. Thought it would be nice to join a Canadian forum. Where I ever found the time to start a new hobby I will never know. Between my software - hobby - company (icom dot va2fsq dot com), my astrophotography, and now this, I sure am busy.
Anyways, I started looking for a mini-lathe mainly for telescope making. I already had a Shapeoko 3 CNC router but I needed something to work on round parts. So I started looking. The lathes from little machine shop looked really nice but once you put in the shipping, the taxes, the brokerage, the risks from shipping damage, it did not look too reasonable. So I decided to get something local, and settled in the King Lathe. It had to be small due to space issues.
The lathe was available locally in Montreal and I brought it home. It was not very dirty or oily but I decided to strip it all down, and clean and adjust it all. Everything was pretty good except for the tail stock. That was a disaster.
First of all, it required grinding the opening to allow adjustment of front to back movement since the slot was too small. Next, there was no way to adjust the angle of the tail stock other than two screws. This of course assumed that the base was machined at right angles to the spindle. It was not.
So I had to drill and tap two additional holes for adjustment. Now , how to adjust?
Well I bought an MT2 alignment bar from India. Its about 12" long and goes into the tail stock. Wow, absolutely beautiful and precise, cheap ($38 with $12 sipping from India. arrived in two days!!!) I then put an MT3 dead center into the spindle and mounted a dial indicator on the carriage.
If the dial indicator was on the top of the bar, moving from the left to the right of the lathe, showed that I needed to shim one side of the tail stock up 0.02". Repeating this measurement from the side of the bar, I fiddled with the adjust for a few hours until I got the bar perfectly aligned with the spindle and parallel to the ways. Overall it's pretty tricky and time consuming.
It's now set up pretty accurately, and it's pretty rigid. I can part 2" diameter brass and aluminum with no issues.
The only thing I am not too pleased with is the sound of the motor. It is very,very loud, sounding like something is really wrong whirling like crazy.. But it works fine. Not having heard another in person I can only assume that this is correct. Only time will tell.
Anyways, I'm pretty happy with my purchase and I'll now post my questions and peeves in another section of this forum.
Looking forward to lots of great posts.
Tom
Tom
