Tig torch adapter?
ShawnR
I bought a Tig torch, 17F, from Amazon, thinking I could just install it on my welding cable. I used to have a flex head and really liked the options it allowed. The torch that came on my welder is a 26. The fitting in the new torch is much smaller and I am wondering if anyone has adapted a #17 torch to a #26 cable/hose. I realized that I will need to be careful with my welding current as the #17 is rated much less than what the machine can supply. Or do most have a #17 torch hose assembly separate from their larger hose assemblies?
The fitting in the #17 is a machine 3/8"x24 thread. My #26 torch has a typical gas fitting, gland nut I think they are called? About 1/2" in diameter? I did not measure it. I do have an old #26 torch head I could cut up and modify but that seems barbaric. And the assemblies are surprisingly cheap. So my only excuse is curiosity and looking to use it today or tomorrow.
I have one like that with a big flat terminal lug, and adapted it to the welder with a Dinse connector to the welding cable. From the machine out it uses the Dinse connector and all I have to do is disconnect the whip and attach the tig torch in it's place. My gas connector is attached to a block with the power cableand you are probably going to have to modify your to get that set up
Ah. ok. Thanks. No problem. I just wanted to confirm that I was not missing an obvious available adapter.
There are pages of TIG adapters out there, so it might pay to go to a decent welding supply place and ask. Take the torch and hose with you if you can.
Like as not, they will set you up, probably for cheaper than you expect.
Thanks @trevj After posting this, I went to the Everlast Welding site where I got the welder and they had a #9F cable assembly on sale. I ordered it up and my (pre-tariff )Amazon #17F fits on it, so I now have an extra cable and 2 flex heads. And then the #26 rigid torch and cable assembly. More equipment than my skills deserve but the flex heads are nice.
Surprisingly enough, these parts are generally not that expensive in a stocked welding supply place.
Last lot of TIG fittings I bought was from (I think) Praxair, in Kamloops, and it really did not seem out of line enough to chase down cheap import stuff.
