johninsarnia
New Member
My main hobby is making small engines and having made several of the spark ignition variety I am trying to move on to hot bulb and hopefully full diesel types. The main challenge is to make the injector pump and the injector itself to handle minute quantities of fuel and in the case of a diesel engine to develop a high enough pressure to finely atomize the fuel. For the size of engine I am interested in (~30cc) a pump with a bore of 1/16" (~1.5mm) and a stroke of somewhat less than this is about the right size.
Looking at full size practice injector pumps rely on having the piston and cylinder made to close tolerances to minimize leakage back past the piston. With the pressures involved (certainly in a diesel engine) it is not possible to use any type of elasomeric seal. I have experimented with using O ring seals around the piston but they do not seem to last very long.
When you read about manufacturing diesel injector pumps they talk about very tight tolerances on diameters and cylindricities down to hundreds of a thousandth of an inch and all the special (hence expensive) equipment needed - which is beyond the scope of any amateur.
In the model engineering world there is someone in Denmark (Find Hansen) who has succeeded in making small diesel engines that work and he has lots of videos on YouTube showing these. In some he discusses construction techniques but does not get into how he makes the pump. Looking at the videos it appears that he just relied on a close fit and there is no significant leakage when the engine is run. I have no idea how he achieves this and he refuses to pass on his knowledge of how it is done.
I am wondering if anyone out there has had any experience in this area? Taking a simple approach, if you just use a reamer to produce a 1/16" bore, find a piece of 1/6" rod that is a tight fit initially then run the two together using metal polish until the fit seems right, leakage is still excessive so lack of cylindricity is presumably the problem. I have a 1/16" lap on order and my next move is to try to produce a more accurate bore then work on getting a piston to fit properly, probably using an external lap.
Any thoughts would be appreciated.
