Tool Shop tools.
Tool
toglhot
just a Backyard Butcher.
Some single use thingies: A cam chain holder to stop the chain dropping into the sump all the time. Better than string or wire because the motor will turn over.
A TDC finder. Made of an old plug which I threaded M10 internally, screwe a bolt in place, drilled and tapped that and screwed in a long M6 bolt.
The degree wheel is held in place by three rare earth magnets, it has marking for TDC and other markings 5 degrees apart up to 40 degrees. The short piece of tube, fits in the central hole and is a tight fit around the socket for centering. Once centred, it's removed to give the socket a little wriggle room.
fixerup
Well done. Sure helps having some specialty tools on hand to get the job right.
Is the quick connect air fitting, used with the sparkplug adaptor to perform air leak down on the engine.
