Jimbojones
Does anyone here sharpen their brazed carbide tools?
I've got a number of used ones and they look serviceable but could stand a bit more of an edge on them.
I've got a green-wheel stone (silicon carbide) so that's hard enough to grind it but I've heard the health hazard just isn't worth it...plus its only single/fast speed so its difficult to get a fine edge.
Have seen a number of diamond files/stones that would allow a lot more control both in movement and dust produced...but no idea what size is most-useful (1x3? 3x6) nor what grit(s) (single girt, double sided e.g. 400/1000). Would assume you could also use something similar to put final edge on HSS tooling but of course, use separate sharpeners for each metal type.
What are others on the forum using?
