I bought a scrollsaw last year from the used KMS section for 50 bucks the table was missing the hold down clamp that lets it tilt.
I finally got around to making the part it took about 5 hours though using a 1/2” roughing then a 1/2” ball and finished off with a 3/8” ball endmill with a .005 thou step over.
However it wouldn’t tilt very far and was modified as shown below this gives me about 30 degrees and is good enough for me. The other holes were for fixing it to a 3/8” piece of aluminum because the cutter rolls over the edge and down the side and using a ball endmill it travels past the machining level due to its radius.
Now I just need a blade for it.
