Rockwell Beaver 32" Radial Drill Press, $300, Lethbridge, AB
I had one of that design many years ago, but found that it was not rigid compared to a more ordinary design. I used it for woodworking, and even for that if was disappointing. "It seemed like a good idea at the time". You can imagine with that length of relatively thin support that there would be some flex.
What you really want is something like this one:
If I only had the space
I have worked in couple of shop that had radial drill presses. They are more of a millwright tool than a machinist. They were very handy. The last shop I worked in had an English Denbiegh "camelback" drill press. They should have bought a radial arm drill press, a much more useful machine.
That DP is pretty much the same as mine. I bought mine through Sears 4 decades ago. Made in Canada, but I never knew exactly where. Could be it's a Rockwell/Beaver product. Fine for wood working, but not very robust for metal work. I figure when I eventually unload the thing, I will be happy to get $50 for it.
