Tool Replacing a spring punch tip
Tool
David
Scrap maker
I have a vintage Craftsman 4054 spring punch that has lost its tip.
Really like the punch as it has a substantial spring and makes a visible mark as compared to my Starrett punch which seems barely penetrate the Dykem/Sharpie.
I'd like to replace the tip but don't know what to use. I don't have any tool steel.
Wondering what else I could use to make a new tip.
The collection of small, broken taps that you undoubtedly have might be a possibility. I have never had one of those punches so I don't know how small or exact dimensions you're after.
It's pretty small, maybe .11" or so diameter.
Apparently it’s smaller than 7/64”…
Maybe I’ll use the D-bit grinder to reduce the diameter of a 7/64 punch till it fits.
How close is it? Could you chuck it in the lathe and take it down to size with emery? At least that way it would stay round(er).
Cheap scribers with replaceable carbide tips are 1/8” shanks. $12 off Amazon.
Looks like the bore is the diameter of a #39 drill shank.
But there's something else going on because the end of the drill only goes into the bore about 1/8" so methinks that it actually screwed in and tip broke where the threads met the body.
:( Getting the remainder out ain't gonna be easy.
Why do we keep going to Amazon and McMaster-Carr still? Just asking. I know it's convenient and all that but with Amazon most of it comes from China via US. 20% on entry to US, who knows what on entry to Canada.
I'll have to write down the date and time for historical purposes.LOL
You provided me with one of the best ideas that I'd probably not have co.e up with...
I'm still using an O1 center punch made in high school. I have diameter sizes like 3mm, 4mm, possibly 1/8". But maybe turning it down more of a headache than other sources?
Heat is pretty easy with a torch & dip in whatever oil you have laying around. Temper in oven at 475 when she's not looking :/
