couple of votes for "just eyeball it", but no comments on how critical the angle is or what the "best" angle (for a given task/material) would be.
I'm with
@phaxtris and
@trevj on the angle being not that critical. Even really is the tungsten you use for most part.
I think unless you get to the point were every weld you make is weld porn I think the small details like tungsten angle are not that critical.
I would focus on getting the basics perfected then start playing around with all the other factors that take ok Tig weld to "weld porn"
When your first starting out you'll spend more time grinding tungstens then actually welding anyways lol.
I personally like more pointy tungstens but I've seen guys use like 30° to not use up the tungsten as fast lol.
I would recommend buying gas lens and run larger cups #8-#12 range maybe buy stubby style torch consumables and maybe a tig finger if you like to use your pinky for positioning. And if your feeling rich maybe a weld craft flex neck.
You can get knock off Tig fingers off AliExpress for like 3$ a piece or buy fiberglass exhaust tubing sock from autostore if they carry it and make one yourself.
This what I used weld with the other day to make splash guard for wifey's cabbing machine I've been poking at.
It's 1/16 aluminum I welded at 72 amps and with 80/20 ballance and I think looking at my machine 200 Freq and 3/32 tungsten Using 1/8 tig rod that's probly open longer than I've been a welder? I don't Tig as much as I used too but I'm still ok at it I think? Also argon is expensive when you buy it yourself so I'm usually on the lean side of gas coverage when I'm at home eg. The blue tungsten lol
Also don't make fun of my shitty sheet metal bending as I don't own a brake of any sort ATM and used a rubber mallet and my table to form the splash guard.
