Power Z & X
On my ToDo list all most forever is a power X and Power Z for my mill. Both are 5/8 shafts. The Z has a castle drive and the X is key drive. I'd like to keep both manual drive handles as well as the adjustable zero dial.
Vevor has a few that look promising to me.
Power Z $180 450 in lbs 37.5ft lbs
Power Z fixed $185 450in lbs 37.5 ft lbs
Power X 1 $185 450in lbs 37.5 ft lbs
Power X 2 $187 150 in lbs
Anyone have experience with these? Comments? How did the install go?
Why the two different X Axis Units? I would have thought 35ftlbs is more than enough for all 3 axis. But the price difference is nothing.
Other options?
Recommendations?
Edit - fixed Z unit link and X1 torque
Power X 2 $187 150 ft lbs 1800inlbs
Other options?
Recommendations?
I have the Power X 1.
Plenty of power, but our shaft and shims etc need adjusting because it tightens up and jams. I end up having to leave things loose. One day I'll watch a ton of videos and figure out the fix
It's really hard to understand why the price difference is so low. I would think the higher torque dictates stronger gears and bearings. If 450 in-lbs will lift my knee reliably, then I don't see why x would need more. Maybe to get a more steady feed speed while milling for those who want that. I just want to get to the other end without cranking my head off.
I confess I'm concerned about 450inlbs being enough for the knee. Ya, it's plenty enough torque to move the knee, but are the gears strong enough? And how does it work with the castle system. I absolutely need manual too.
I recall John Conroy did a great writeup on his knee power feed installation. Years ago but presumably still in our system. There are some things to know regarding setup & shims that might be beneficial to read beforehand.
I'll see if I can find it. Thanks Peter.
Edit - I think this is it. No idea why @John Conroy called it a 'New X axis power feed for my Ferro milling machine' though. His thread dives right into Z.
Other options?
Recommendations?
I was just looking at those 3 drives not more than an hour ago, the 450inlb unit is in my cart.
The X 2 appears to be 150 in-lbs (not foot-lbs) if you look at the metric specs (only 16.9 NM torque).
Wow! Good catch Mike! I checked it at least 3 times. I didn't like the way they called it pounds without feet.
That settles it, X1 it is. I think I'd like to start with the knee unit though. That's the one I really need most. I use a Dewalt drill and a castle drive now. Obviously, if I use a drill now, it needs a power drive.
Looks like they are trying to reuse the X axis feed to work for the Z axis as well, I would like to have a power feed on the Z axis too but the drive shaft on my mill is 11/16" and it's not a big mill at all.
Hard to believe a Bridgeport mill has a 5/8ths Z shaft.
It's just a cranking shaft. The actual Z Screw is much much bigger.
When I click on your "Power Z" it shows an X power model!
Fixed. THANK YOU!
The unit on Amazon that you posted looks to be the same as the one from Vevor direct, but it looks like Vevor direct is a few bucks less. And maybe I can find a discount code. For sure, I have Vevor points.
I guess I could pull the Z axis shaft, lathe down cranking portion to 5/8" and then put a sleeve in the cranking handle in case I want to use it again.
I would not do that unless you also have the ability to cut a Keyway for the drive.
I guess I have to see if I can find a manual for the power axis system.
Grind a piece of hss, stick it in a boring bar and use the quill like a slotter, it might seem as slow as molasses in November but looking back at the big picture and it took no time at all.... :p
