3" copper drain from the toilet. Connected to plastic which is connected to the toilet flange after an elbow. The rubber transition is the specific one for copper to plastic.
Unfortunately due to age the bottom of the almost horizontal copper section has worn/aged and how has cracks and therefore a leak.
I managed to cut off the offending copper section leaving just enough for the rubber transition. Some rework with the plastic and it's all back together. And as I tightened the two screws on the transition I see the split in the copper is migrating towards the cast elbow. So this is a real temporary fix although first flush didn't leak.
It looks like I have to heat the cast elbow and remove the old 3" copper pipe piece and replace it. I don't think normal propane is hot enough. Don't dare use my Oxy/Acc as likely too hot. I'm thinking one of those MAPP torches?
And best to just solder in a new longer piece of copper and then redo the transition?
edit:
Here's a picture of the piece of pipe I cut out.
edit:
