ringground
Hi from Salmon Arm I have just bought a17 inch delta drill press it has a 2 mt would it be possible to make it a 3 mt
If you replaced the entire spindle with a MT3 one or are you wondering about having it bored out to 3mt? I suppose there might be enough material to remove to get up to a MT3 but that would require a internal boring job followed by a mt3 reaming. I highly doubt that much could be just reamed out if that is what you were thinking.Hi from Salmon Arm I have just bought a17 inch delta drill press it has a 2 mt would it be possible to make it a 3 mt
At the very least you would have to take the spindle out to bore it as it takes some horsepower to bore a MT taper. I have a modern asian made drill press and those machines of the same size are basically the same and a spindle swap is likey possible with those as so.e came with larger spindle MT than others. I wouldn't expect you would be so lucky with an old delta.i was wondering about boring it out to 3mt and if any one has done that i tried to send pic but the file was to big i will try to send a pic of the spindle
