Now this woke me up
darrin1200
Darrin
Put a new link belt pulley on the lathe, 10 minutes later
CLANG….CLACK CLACK CLACK
So now I’m looking for a two step pulley for my motor.
SM 10” Utilathe
The parts manual just says pulley
I usually use Amazon for my parts search, but my minimal knowledge is not giving me a successful search description. LOL
I’m not sure if this is the original pulley. If anyone has a source or original specs, I would welcome the info.
I believe the pulleys are measured by the outside diameter which would make this a 4” step and a 3” step.
I believe it is to fit a 1/2” v-belt.
The hole is for a 5/8” shaft with a 3/16” key slot.
Hopefully @slow-poke or @Brent H
Will chime in with some insight.
At least I can still use the lathe on the slow range.
Thanks
Youch, if all else fails you may have to make one. Can the pieces be welded back on as a temp fix until a replacement comes along?
Princess auto may have what you need.
Try Comotech in Ottawa, great guys to deal with, ask for Braydon.
If not Motion Industries will have.
My lathe had a non stock motor with a single sheave. That has now been replaced with a 3HP, 3-PH!
Surgeson, may well have them, but might be pricy. They quoted me $206 for a taper lock pulley yesterday and I got the same thing at PA for $36
I hope to go 3ph, but not this year.
I’m going in to Kingston next week, I’ll check PA.
