TorontoBuilder
We had Prime Rib for New Years Eve, so we had left overs.
My favourite way to serve left over prime rib is as hash. I think the key to the best hash is to not overpower the beef with too much seasoning, or to overcook the beef, and to add a bit of moisture at the end of the frying in the form of a complimentary sauce.
So I start by rendering chunks of fat I've reserved for just this purpose, and then frying the onions and mushrooms in the tallow until tender and golden. Then I add the leftover roasted potatoes and fry enough to heat thru and put a little crust on the edges of the potatoes.
Only after the potatoes are crisp and hot will I add the left over roast that I've run through my meat grinder along with a fair bit of the fat cap. I'll heat the beef until it is just warmed thru, then douse with about a 1/4 cup of my secret sauce, mix well and remove from heat and serve.
Of course because I was taught to top with a runny fried egg, so I did. It's all about the timing... eggs go on at same time the sauce goes into the hash. I garnish with a bit of sauce as well.
Also reheated the roasted parsnips, carrots and brussel sprouts to add on the side
Proof the egg yolk had sufficient flow factor (sorry about the poor lighting)
