![IMG_1358.jpeg IMG_1358.jpeg](https://canadianhobbymetalworkers.com/data/attachments/58/58379-90c97c0b546b25249afc1351c2602fe3.jpg?hash=an0WDi0MEr)
![IMG_1359.jpeg IMG_1359.jpeg](https://canadianhobbymetalworkers.com/data/attachments/58/58380-4a7480936a86895b9bf8541e6d6918c8.jpg?hash=sdKpCeTgWc)
![IMG_1360.jpeg IMG_1360.jpeg](https://canadianhobbymetalworkers.com/data/attachments/58/58381-6ecc52ecae196a7d523706821afd9a1b.jpg?hash=_H0O-gnrce)
Hello folks. I am rebuilding older BP longitudinal power feed gearbox.
Shifter handle is missing- probably was broke and thrown out. Now I need to replicate something similar - I made a keyed collar for the sleeve and bent a handle itself from steel bar .Now I need to attach lock pin which will be moving through positions on the casting. I can make it adjustable in axial position ( see white arrow on the handle ) I can mill a slot along the handle, but I also will need some adjustment in cross direction as it defines proper gear mesh inside the gearbox. What might be creative solution to make lock pin adjustment in two directions?
