Myford Super 7B Metal Lathe for sale asking 4,250 CDN
CenturyDarkroom
New Member
Located in Toronto
Over $2,000 in new parts!
New headstock bearings, spindle cone bushing re-scraped, new oiler wick, new countershaft bushings, completely rebuilt clutch assembly with new bearings. New V-belts.
New lead screw bushing, brand new cross slide and gibs, new cross slide feed screw with upgraded thrust bearings, new end plate, new top slide base.
The bed has been refinished to remove wear. Everything is tight and smooth.
The lathe has a great range and can run at 2500 rpm top speed without issues.
Quick change gearbox for screw cutting.
A fantastic lathe for the home shop! The only reason I’m selling is that I’ve got a newer Myford with power cross feed.
(Tooling, accessories, tray and raising blocks are not included.)
Wow looks like a nice lathe but if a fellow is spending $4200 on a lathe alot of good options are available both in used and new. Good luck on your sale ( and that isn't sarcasm)
