garball
Log into Facebook
Log into Facebook to start sharing and connecting with your friends, family, and people you know.
www.facebook.com
But will most likely get it...... Or very close to it.So, totally not worth it.
Sure, I’ll spend $7200 for old iron, instead of buying one of these for $5k US.
DRO, power cross feed, DI-4 chuck mount, separate leadscrew and power feed shafts, variable speed. All stuff I’m willing to sacrifice to own a Myford.
<sarcasm>
The problem with MyFord is that it is very old design model makers machine. Not professional at all by 1950s standard. Super 7 tried to fix some of the glaring problems later on, and to some degree it did, but the main thing it was that it is still a model makers machine.
I have taken parts of my MyFord apart and through better then some low cost Chinese stuff it was clearly not even close to "top notch". I would venture to guess that if we did take a brand new BB (so certainly not top notch) 10x22 it would be more precise machine then your average used MyFord.
I think the problem here is that someone taken apart some cheap Chinese junk that was from say 2002 and say "OMG". Heck, plenty of "tools" from China today & most from India are "OMG". But things move fast, for China 2002 and 2022 is like 100 years in US terms, i.e. its like looking at 1922 car and 2022 car - say a Ford. Same thing could be said of Japan.
Also Chinese frequently compete on price alone & the cheapest half crap that market accepts is in. So its partly our fault for accepting some cheap crappy stuff.
Notice that most brand name drills are made in China & many of them out perform US made drills - heck Project Farm did a check and China was doing as well as US and others. It was just China competing on quality not price.
Now I am not against old Iron, but come on pp - technology moves forward even in machine space & Chinese / Taiwanese stuff which was not made to be cheapest possible will easily out perform design circa WWII that was to add centered around "economy" solution.
I think one of the allures of owning old iron is being unique. I mean anyone can get a 10x22 from BB - but having MyFord may make you feel extra special. Its like owning old classic car. But come on, I feel few pp will say their 1967 Corvette is better then say 2022 as far as driving performance is concerned - you do not see professionals race old cars at all. OTOH 1967 can be more expensive then say 2022 due to "collectors value".
Just add fuel, lots and lots of fuel; what ever doesn't get burned gets breathed in by anyone following too close. No electronics, no extra plumbing, just exactly what is needed and nothing more. Is that what you meant @Susquatch ? There are probably still black circles on the wall of our parking spot at Palace Place from start upsMost mechanical electronic things get better with time. I would never argue that. Continuous improvement is a fundamental part of progress.
But that said, give me a 1970 muscle car to drive any day of the week. It's more than vintage mystique or collectability. It's also raw uncivilized pre-emissions power that feels ABSOLUTELY AMAZING!
Just sayin..... LOL!
What do you think about manual machine tool technology has improved in say the last 50 years? DRO sure, but its an easy bolt on (and no super important for a lathe imo). What else? About all that has changed in the last 50 years for manual machine tools is they've gotten cheaper buy using lower quality components, cast iron and materials and the big one, the sacrificing careful fitting of bearing surfaces; an unseen attribute unless you print and survey them, that is perhaps the core of what makes a quality machine tool.
Suppose you found '68 DSG or a Schaublin 102 or Monarch 10ee brand new in the packing grease in the back of warehouse, so there is no wear. Wear is legit reason to pass on old...put then you;d be passing because of wear not "old" technology. How is a manual machine made today better than one of those because "technology has moved forward"?
Not for me, I love driving a modern car. 100x better than the crap of the past. Buddy of mine ran a 10.2 quarter mile at Caugya in an Audi S4 with a 3.0 engine. A car with a 3.0 in 60's might not have made it up the hill. Machines or cars, its only about the performance. Thats why I've filled my shop with Schaublin, Levin, Monarch, DSG, Holbrook, Rivett, Boley etc lathes. Nothing under 25000 made today is remotely of they quality there. There are lots of reason to buy new but I can't see how there is a 'new technology is better' argument in the realm of a manual lathe
You said it same way as I did - old iron is fine as long as it was something quite good in its day - hence in your shop I probably will not find... Atlas.
Say you found an old MyFord in grease or an old Atlas - there is a big difference here between these two and 10EE.
Its like finding old Chevy Chevette still in original condition vs. finding an old Ferrrari in original condition. Few pp will be excited about the chevy. But never used, in perfect condition 1970s Ferrari? That would made the news.
Back to MyFord, what does a modern machine have? Well, for starters, unless you are talking about super 7 (I think), they have modern bearings! Then they have other cool modern stuff, like power feeds, X and Y (only Super 7 has both), usually they have at least one lead screw and another shaft for power feed. Big bore - I think ML7 both versions is like 3/4? I know its tiny. Most machines this class have 1.5".
Fine speed control, most small machines have infinite speeds via VFD - they also have much bigger motor (you can do so in ML7 as well, but then you need to play around with belts as belts have limited amount of power they can transfer.)
I also believe modern 10x22 will be out of the box better ground then brand new MyFord.
Modern chuck mounting - not a screw on.
Certainly more beefy design, including tail stock.
Cheaper and easier to get accessories / parts - did you know that a used gear box for MyFord costs like just under $2000 cad (!)
Yes I know 10EE has a lot of that - and so does my Chipmaster - but MyFord does not!
When comparing used 10EE in average condition and this MyFord in average condition I would venture the 10EE should sell for like 30k (!) or more, you get so much more of a lathe!
So the main tech push in manual lathes for workshop use (not some specialized lab) has been in adding luxury features to economy machines while at the same time dropping price point a LOT. Features that 10x22 has build in, would be found on similar size lathe in 1950s only on top of the end machines - like I stated somewhere else, our time traveling 10x22 would only be joked about regarding it super light weight. It would be seen as uber light weight 10EE.
As for more specialized manual lathes they are getting more CNC functionality, such that infinite feeds / threads. Also more bearing choices are pushing for big bore lathes all over the place. Auto oiling is now a "mid level" feature.
Tom, forget about Myfords. My post was about your idea that modern is better because of technology. A VFD is a cost saving measure and a downgrade from a manual transmission. You are mistaken if you think well done plane bearing is inferior to low cost Chinee roller bearings (in manys and appications they are superior), however lathes having rolling element bearings have been around for probablly 100 years or more. Nothing modern about the bearings. Cam locks around for the about same. Power feeds on X and Z, forever.
The best machines made (the few that are left), are still scraped in btw. You don't see because they scrape parts into the ground bed. Its difficult to grind some mates, ie head-stock alignment, carriage to bed etc. The dovetails aren't that big deal, I've ground them, still....you think they all have good bearing now? They're mess....when you someone printing one, a new, they are terrible. Before Standard Modern shut down a few years ago its how all theres were made, hand scraped to the bed....of course that's probably in part why they are not around (or least around as they were).
I'm still not hearing anything as to why technology has moved forward such that "modern" machines are superior to those made in the past
But they do not use cheap bearings at all
these bearings are easily more precise then what MyFord has.
Even 10EE has different equivalent to a VFD
I stand by my original assessment.
