Motor capacitor procedure
What is the proper way to replace start/run capacitor's on a motor? Assuming they could still be live I've read: Disconnect power from machine. Remove wiring from cap terminals & immediately tape them to avoid inadvertant jolt while removing. Then on the bench, 'short' them for storage. Sounds electrifying. Is a screwdriver with plastic handle considered safe?
Depending on the degree of danger you can choose a variety of options.
For small single phase motors the start capacitor can be safely discharged with a screwdriver that has a thick plastic handle by placing the metal shank across the capacitor terminals.
Like @combustable herbage already mentioned if you don't like sparks you can build a discharge tool and leave it connected for a few hours or overnight.
There are online calculators that can help you determine the time it will take the resistor to discharge the capacitor:
Most motor capacitors are cheap and self discharge in a few hours. They don't have to be expensive low leakage caps, so they aren't.
If you don't like sparks and don't want to make a discharge circuit, just leave them sit overnight.
I once saw a fellow use a light bulb in a light fixture with leads. When the light quit glowing the danger was over. For 220V motors use two bulbs in series.
