Megar arc 5040dd
I figured this was probably a more appropriate place for this. The rest of the discussion about this mill is here https://canadianhobbymetalworkers.com/threads/new-to-me-zx45-milling-machine.7314/ this will just be about the actual project of building a base for the mill.
So 2 problems needed solving 1) the roller base that is came with was a little wobbly since it was just a regular roller base for tools with 2 pieces of 3/4" plywood holding all the weight at the 4 corners. And 2) and probably the most important problem the mill was just way to low to use unless I was sitting on a mechanics stool. I am 6'2 with back issues having to bend that much makes using the mill not enjoyable so it needs to be raised up.
This was the base the way it came when I bought it.
The plan was to remove the plywood and replace it with some 4"x4"x.125" tube I have had laying around for about 15 years. Then add some levelling feet to the tubes on the sides right by the casters.
Got the frame all welded up. The welds on top and bottom were ground flush to it can sit flat on the mobile base and the cabinet can sit flat on the tube. The cabinet will then be welded to the tube at the end to make the cabinet and base one solid structure.
Then snag I hit the first and hopefully only snag. Its still way to short deep down I had a feeling 4" wasn't going to be enough but I wanted to use up the tubing.
More in next post.
More in next post.
