Milling machine, $1500, Neustadt, ON
1fab5c99-8dcd-4b6f-86d3-fad6ab6d2fa2
LenVW
Process Machinery Designer
I think you could haggle with this one.
Neustadt only has a couple hundred residents and as I recall . . .
a little Hotel with bar called the Locust Lounge.
Good times in the 1980s !!
Honestly, if everything moves, the motor runs, and the spindle doesn't sound like a chainsaw, it is worth every penny.
I didn't notice that at first - I think you could just the power feed and pull the cutter through he work piece without having it spinning.
By golly I think you nailed it! It's not a power X, it's really a high thrust shaper! You could make a full length keyway on a 36" shaft with that thing and it wouldn't even burp!
