Hi,
A buddy of mine -Marius - is working on a CNC mill conversion. He needed to enlarge the lead screw area to fit ball screws in. He gently used an angle grinder to open it up over a few days to minimize heat. However the front of the ways are now 0.004" wider than the rear. The casting moved on him. See pictures. How should he fix this? I had a brute force idea to simply run a dove tail cutter and straighten it out by taking off 4 thou from front to back - on both sides I suppose. This is a hobby sized desktop mill - it's a king but very similar to the the usual CX602 from craftex or the grizzly models. The ways don't appear to be hardened. See the red lines - the front one measures wider than the rear one. The other issue is the gib no longer fits correctly due to the changed dimension on the ways.
Advice please?
Advice please?
