Mill dro
With my DRO on the X on the back, I put the linear scale high enough that my oiler is below the linear scale. It is behind the reader until I adjust the X axis far enough, then the oiler is visible and I can get access too it.
You might also like my Z gib locks.
After installing the Z counter balance, moving the head up or down was much easier and I could then do it from the front of the machine (using a smaller and faster wheel instead of a large crank). I added a Z gib linkage so that I could reach both the Z wheel (on the left) and activate the gib locks at the same time.
View from front, note Z wheel on left and lever on right:View attachment 58249
View of counterbalance cables and Z gib locks linkage:
and a couple of closer views of the linkage:
That is amazing! Does the counterweight help that much? What are you using for weight and how much weight did it take? Does it just free hang behind the machine or is it guided so it doesn't swing around? I thought my project list was already long enough now I need to add this to it 😀
This thread has me thinking of added more mods to my mill. I have a vevor dro set with glass slides that I would like to install on my mill. They have to be cut to length, so I might look at doing that today.
I thought it might need guides - but no it does not. The counter wt is 225 lb of scrap steel rods. The Z hand wheel now requires about the same effort as the X hand wheel.
To avoid repeating myself- see this week's thread "Looking for an appropriate motor" post #27 in the link below
or come for a shop visit - the most fun I have with any shop toy is doing modifications
Thanks for the link I added those pictures to my project ideas folder. The list gets larger faster than it gets smaller.
