This project has been a long time in the making. I recently built a GRBL CNC controller and last week got a Sherline 5410 mill. This evening I made my very first isolation routed PCB. This first attempt is for an SMD RF pre-amplifier so is only 40mm X 50mm. I'm 90% happy with it and it will only get better from here. I don't have the right collett yet for the cutter and am waiting for a high speed air driven spindle. Think dentist drill. This attempt was cut using a Chinese cutter in a 1/4" Jacobs chuck at 2800 RPM; definitely not an ideal speed for this operation. I have a high grade carbide cutter and with that mounted in a collett and run at 30K RPM or so will make for a cleaner finish and of course I can then up the feed rate. Other improvements - reduce the depth of cut by almost half and make it smaller. Maybe microstep more - currently running 400.
The next project is to migrate to LinuxCNC. I have a vintage PC that I just got loaded and working. I went through 4 duds before I got one with a low enough latency to software step.
All that is required for it is a breakout board and hookup to the steppers to make it go. I'm new at this so for now GRBL works fine for me.
Anyway, that's what I've been doing..
