Making a Fixture for a Grinder (2023.03.04) --Instant upload
a smile
Lifelong hobby - cold iron
切割尺寸:310*260
19:30-------------------------------------------- ------------------------------------------
Three hours later ------
30 steel plate holes, tool machine -FP5/mh800, not familiar with programming, so manual punching,8.5mm. I will work hard to learn programming -----
The above two steel bars are purchased 25mm flat keys, which are also drilled in turn 10.2mm, with a spacing of 72.5mm*5
Hand drill chamfering is also fast
Starting grinder
Simply coarsely grind the opposite side
Fasten together with screws
t's 11 o 'clock at night. That's all for today. I'm a little tired
Good night!
Picking up where we left off last night:
13mm Hole spacing 13mm A total of 20.
The way you remove the screws
File the burr
Make a simple cutting table
Flat cut, rounded R3
Put the tooling on and try it out
Clamp the upper grinder for processing
The finished product, relatively perfect
Because it is not professional enough, it will take a long time. With the increase of experience, there will be faster technical improvement.
This is the processing tool of the afterrod in the chuck wrench designed by me. Maybe it will be sold in Canada in the future! Thanks for watching!
