Make a special hexagonal sleeve
a smile
Lifelong hobby - cold iron
Start with 3D drawings, assemble simulations
Use a thick-walled tube
Material 42crmo, size: 60*25*100
Lathe into short tube (inside and outside turning), EDM wire cut hexagonal
2023_07_26_15_31_IMG_0788.JPG 2023_07_26_15_39_IMG_0795.JPG 2023_07_26_16_26_IMG_0798.JPG 2023_07_26_16_27_IMG_0804.JPG
I think it's not perfect production, it's not perfect design, it's not conducive to production, it's not beautiful, I'll redesign it and make it -----
PaulL
Technologist at Large
He was working on an EDM machcine in another post. It looks like to me he has it working. The second photo looks like the hexagon is being cut on the EDM.
Ah - that makes sense - I couldn't work it out on my phone - the wire became invisible. Desktop FTW.
a smile
It feels weird after the thread is done. The first is not beautiful enough, and the second is not suitable for batch processing.
Change the design, redraw the drawings
Start with wire-cut EDM
The center line of the hexagon is used as the base to reprocess the outer circle Add external thread M54*1
Horizontal milling shaft index drilling--6.8mm Double punch16mm
M8 threaded spring bead
Plug tight fit, strong pressing together
2023_07_28_20_49_IMG_1033.JPG ,
Make a big nut M54*1, vertical milling curved teeth to increase the friction, I do not know its specific name, anyone can give it a name?
QQ截图20230728210451A.jpg 2023_07_28_20_50_IMG_1045.JPG 2023_07_28_20_54_IMG_1055.JPG 2023_07_28_20_52_IMG_1047.JPG
I will continue to optimize the design until it is more reasonable and more beautiful, and I have EDM two reserve parts(It also helps me verify the stability of the modified EDM machine)
