Lincoln Magnum spool gun
Michel T
New Member
Hello out there, would anybody know the differences between the Lincoln Magnum 100SG spool gun and the Lincoln Magnum Pro 100 SG ? They dont have the same price tag, and I was not able to get a decent answer from Lincoln tech support. To suit a small mig WeldPak 180 HD ( Lincoln)
Many thanks !
Michel
Many thanks !
Michel
I was stuck in the same place a couple years ago trying to sort out which one was actually the right one and was one worth the extra over the other..... All I wanted to do was stick a little bit of aluminum together.
Solved the debate by buying a tig welder and I have been smiling ever since.
Sorry, it doesn't answer your question, but does represent my decision when facing the same decision.
When I bought mine one was the spool gun kit. The other was the spool gun kit plus the switch and wiring for different welding machines. Not sure which is which tho. Mine works good, as good as an armature can say.
