lucsimoneau
Hi all - looking for some insight for my manual lathe.
It's a CT-1440B King Canada Back Gear lathe and I'm thinking about installing a VFD so Ì don't have to fiddle around with belt changes and back gears to get spindle speeds.
Current motor is a single phase 1-1/2HP 220V motor running at 1720 RPM with a 3/4" keyed shaft.
The motor I have on hand is a Weg 2HP 3Phase 220V running at 3450 RPM. Shaft size is 5/8".
The question I have is the following: with double the motor speed, will this cause any problems in obtaining low speeds for threading and other slow speed type applications? I will not get rid of the back gears and pulleys so they could be used if needed.
Has anyone else gone this route to change their main motor?
Thanks!
Thanks!
