I decided to replace my lathe V belt on my 14x40. Its starting to look a bit tattered but mostly its making this powder grunge inside the cover & on the gears. The label said B29 so that's what I ordered from local NAPA. Unfortunately its longer than my stock belt. I thought he said 32" which works out tis 812mm & when I measured came up to something closer to 750mm, but I didn't spend much effort thinking its like ordering a bolt. Apparently not. I could see if the old one had stretched & was longer but this is the opposite. I installed it on the sheaves but 99% sure I don't have enough motor plate swivel to tension properly. Any ideas?
I didn't search extensively but similar dimensions keep coming up under B29. Maybe Taiwan didn't attend the international V belt Dimensions Conference? 🙂
http://www.vbelts4less.com/B29--B-Section-V-Belt-5L320_p_14079.html
http://www.gprindustrial.com/en/b-section-v-belts/194-B29-classic-vbelt.html
<update> maybe these dimensions will be useful.
- original B29 belt = 30-1/8" outside circumference
- Napa supplied Hi-Power II B29 belt = 32.5" O.C. (hmm.. 0.5" longer than the web specs, but 2.375" larger than mine)
