Carbide inserted tooling with a carbide backing plate under the insert are much more robust and resilient to interrupted cuts. Typical 3/8” or even 1/2” (10mm or 12mm) offshore tooling does not usually have the carbide backer plates (probably to save height space and cost). The lager stuff 3/4”, 1” and 11/4” shank tooling most always does have the support plate.
I have not (yet maybe?) shattered a supported insert doing interrupted cuts (yes, they are all 3/4” or larger tool holders). I have had quite a few of them bust when they were not supported. Could also be the quality of the insert - the unsupported ones I have are offshore specials…
To the video: the fellow is a very good craftsman. He knows the limitations of his mini lathe/tooling. He has made a lot of extra tooling/fixturing so he can get the most out of his machine - and he does!
As
@Dabbler states above, that VCMG insert has very sharp edges (like an HSS tool would have) and depending on the carbide, might actually have similar properties to a good HSS tool. Since it is being used on a mini lathe, only shallow DoC are usually taken because the lack of rigidity and torque (you can see/hear these limitations when he is drilling/counter boring). To be sure: I am not knocking the mini lathes!
Do I use carbide on rusty metal that require interrupted cuts - absolutely. Do they grenade - no. Do I use the most expensive “finishing” inserts - no. I use roughing inserts - they are made to withstand the stresses better.
I also slow right down and try to take a bigger bite (big DoC) to get first of all, under the rust/scale in one go and, two, to reduce the number of passes requiring an interrupted cut.
