Lathe headstock oil question
Six O Two
(Marco)
I hope this is pretty straightforward but oil discussions can be such a can of worms...
I need to replenish or replace the oil in my lathe's headstock. The user manual calls for iso vg 32 oil in the headstock (iso vg 68 in the apron, which I already have). I'm led to believe that SAE 10w is equivalent to ISO 32.
I've found these two different oils at Canadian tire:
$13.99 MotoMaster Compressor Oil for Industrial Type Air Compressors ISO 32, 946-mL
$6.99 MotoMaster Non-Detergent Motor Oil, 946-mL
Is there any reason I shouldn't just go for the cheaper one?
I hope this is pretty straightforward but oil discussions can be such a can of woms...
according to the resources I've seen yes on a viscosity basis SAE10W is equivalent to ISO VG32.
That said I bought hydraulic oil from canadian tire for my chipmaster gearbox. They have a 32 ISO product too
Here is one.... https://canadianhobbymetalworkers.com/threads/lathe-gearbox-oil.2198/ But I don't think it's the one you are thinking of......
Yeah, there's also:
and this one has a lot of oil talk as well...
or this cheaper one
Hey, thanks for these recommendations! Not sure I'll ever need 5 gallons of the stuff, but with that lead, I managed to find it in 5L quantities in-stock at my local store. Should be perfect.
I was worried that the AW designation was like the EP designation and potentially damaging to brass, but from my reading, it seems to be zinc-based and should also be ok to use on yellow metals. You guys probably knew this already.
Oh great. the ISO 68 is not available in 5L
It's nice when you can get what you need at Canadian tire rather than having to hunt down speciality supplier like I had to for my variator equipped lathe
Canadian Tire is a 40 minute drive to the next town over for me, but I get what you're sayin' ;)
About the 5L ISO 68, do you mean in general, or currently at your store? Because clearly they sell it, or sold it at some point.
I bought this from my local CT a while back, been working well
I've heard the NAPA type generic auto parts dealers & Princess Auto also carry this kind of oil too, although container size & viscosity always seems to vary. CT happened to work out for my requirements. I hate storing pails of stuff I'd be hard pressed to use in a lifetime, so if you can find a share buddy & just use a nice clean container like windshield washer fluid or whatever. I use the same stuff for the lathe 'drip mat' system feeding by gearbox, occasional wipe for feed/lead screw etc. Its useful to have around the shop.
The viscosity might be the same between the 10W & 32 ISO but the ISO is probably a non-detergent oil that wont foam up during use, the 10W may foam up enough to hinder/interfere with the small "splash drain-drip holes" use in a lot of off-shore lathes to lube the headstock bearings
