I posted this on another subject post, but I think worth initiating here as its own theme, so copy-pasted.
I don't do a lot of metric threading but the few times I have, I have been greeted with an unnatural chug-A-chug sound, coming from the gears. I chocked this up as introducing new gears to the train from my normal IMP setup in order to do metric threads and/or additional gears to the train, 4 surfaces vs 3. I had the same tooth spacing about right with the paper trick & they are always well lubricated. Well this time, it sounded its typical chug-A-chug growl, then it improved a bit. Then after an hour of threading a new semi clackety noise started which I did not like. I looked at the gears & observed they had slipped out of position just a bit, yet all the bolts were tight.
Adjusting the gears on the swing arm has never been smooth. After some investigation I could now see what was going on. The curved slot is not machined, its just cast so lots of flashing & irregular width. At the position I was adjusting into, one side of the slot was hanging up on the bolt shaft. Not only making positioning difficult, I think it was actually putting some undesirable bend into the big gear plane. So I just ground & filed some clearance in the curved slot until the arm moved smoothly & unencumbered over the bolt. Instant happiness. The gears immediately quieted down. Knock on wood. So sometimes its these QC headaches that cause secondary problems.
So after posting ^this^ I came to realize my noise improvement was real but rather confined to the lower speeds. When I progressed to higher speeds I could hear still hear the intermittent noise in the background. I think what going on is when I set the gear train to 40-120-40 or 40-127-40 life is good, very quiet. Its when I go 40-127 on one plane & 120-40 on the other plane (regardless of flipping the big gear plate around 40-120 & 127-40) its this combination when I hear the chug-a-chug. This makes me think the 2 gears on the 127/120 fixed cluster are not exactly concentric. I haven't pulled out the measuring stuff yet, so more to come.
But it seems to me I hear about this same 'metric threading noise' issue from folks with similar Asian lathes. Now maybe what is actually behind that is 4 gear surfaces meshing together (while metric threading) vs only 3 (while imperial threading). That would explain 'more' noise, but not 'intermittent' noise. Before I go too far down this rabbit hole, does anyone else share this same noise issue?
