Canadium
Ian
I finally got around to checking the accuracy of the bed on my small 9 inch South Bend lathe. I took advantage of the fact I currently have the lathe all in pieces to take the entire bed and put it upside down on my 3' surface plate so that I could check deviation in the bed with feeler gauges. To my surprise I found the only significant deviation was a uniform 1.5 thou depression under the head stock. Since there would be no wear under the head stock I assume it was manufactured this way and that there is actually no appreciable wear on this bed. Any thoughts/opinions?
