I’ve lapped cast iron and steel. No experience lapping granite. Or measuring flatness to extent needed for a grade A surface plate. Am semi seriously thinking about getting a granite straight edge for use as a master for re touching longer cast iron straight edges. No space here for a surface plate bigger than the 30”x48” I have. Thinking granite at least (but could be longer) 76” long 8” wide 18” deep. Want grade single A as finished result. Easy to hang on the wall, out of the way. (Yes, I know what it will weigh)
Since granite straight edges like this are not off the shelf items, how crazy am I to consider getting a big, cheap, out of spec surface plate, cutting it into slabs sized for above needs and lapping them. Ideally sell the extra bits to like minded individuals. Easier/cheaper just buying ready made to spec from one of the big companies?
This is a somewhere between pie in the sky dreaming and willing to write the check today for me. Thoughts?
