KO Lee cutter grinder belts
cuslog
So, recently purchased a KO Lee Tool & Cutter Grinder (B360 model). Works fine and I'm enjoying having it. However: it's the older flat belt type, I only got one belt and 6 or 8 flat belt pulleys with it. The one belt I got has seen better days and I'm thinking I should find more flat belts or convert it to a more common (available) belt type. Anyone know of a source for those flat belts or suggestions for a type of belt to convert it to?
TIA
There's these, key is a super smooth joint so it doesn't create vibration and they are excellent
Also Habasit who many would say are the best. I've got a few and they are great.
check out Winky ..... this guy knows flat belts, will sell you the Habasit, joined or unjoined, and in one video has a very cleaver design for putting the taper on the belt joint, as well as a how-to on joining them
Thanks for that !
I think I'd just have "Winky" make up some belts for me - I have enough other projects and his pricing seems relatively cheap.
Now, to see if he'll ship to Canada.
You are welcome.
I agree with minimizing more projects, but so often you have to thread the belt through stuff before joining it like on a lathe headstock.
