Is this paper there to do what I think it is?
TorontoBuilder
Watching a video trying to learn a bit more and I see the fellow place this paper with a cut out on his workpiece.
Behind it is a steady rest.
So is the paper to keep swarf from getting on the workpiece and then getting stuck in the bearings?
It is clever, and not likely to do much damage if it get caught (other than potentially throwing swarf everywhere).
It is interesting that they’re protecting the shaft with copper covers on the 4-jaw chuck, but putting a real burnished ring on the shaft where the shaft is running on the bearings.
My guess is the burnishing ring from the bearings isn't as bad as seeing serrations from the chuck jaws.
I vote for swarf gaurd. I use cardboard and cardboard boxes for that all the time.
As that post says, I use them extensively on my mill. I've added a few more cardboard chip guards for the lathe since that post too. Dirt easy to add cardboard chip gaurds to a steady.
On a lot of old lathes, it is pretty common to see the steady rest has been smashed at some point and repaired. I haven't seen it happen but I'd guess that swarf getting in between the work and a finger would be a leading cause. So the paper looks like a great idea to me. Plus, I've seen Curtis from Cutting Edge Engineering doing it on Youtube.
