Indicator lamp
I'm going to guess you meant "no problems".
I'd bet pretty much every one has dual voltage wall warts sitting in a drawer in the house or shop. PA has a wide variety of LED lights that fit what ever level of cheap frugal you are. You could buy a few of these lights and put one in every room of the shop and one over your head in the bedroom. lol
Your right "NO" problems. As I was typing my brain said NO but the message never made it through to my fingers🙂
How about a pilot light switch:
Or you could use a dryer fan sense switch to power a light.
https://www.metalworks.com/shop/p/reversomatic/dryer-amp-sensor
People turn compressors off?
The only time I unplug mine is when there is some kind of service needed, electrical, oil change etc.
Do you have a bunch of leaks that necessitate turning it off ?
No but it's outside in a lean-to on the side of my shop so out of consideration for my neighbors I don't like it to run when I'm not working.
I turn mine off, but not because of noise. Nobody would care here. But 30 years ago or so, mine blew a shutoff valve and ran all night. The motor overheated and bad things could have happened - but didn't. Ever since then I turn it off when I leave the shop. Why take needless chances? Ever since then I only turn it on when I need it.
Once upon a time I needed it almost every day. But ever since the dawn of the new Era of convenient high powered battery tools, it rarely gets used. Why leave it on?
The problem is if the ball valve between the compressor and the shop is on a few days not in the shop would drain the tank as the compressor is disabled.
This sounds like a plumbing problem. I can bring mine up to pressure, turn it off, and not use it for weeks and the pressure as indicated at the gauge does not go down at all. Unless I leave one of the downstream valves open with some tool attached. What I need to remember is not to turn the compressor on or off, but to shut the valves at the ends of the lines. If they are shut pressure holds indefinitely.
Nah, just being cautious. Except for desk lamps & the computer, anything w/ an electrical plug gets unplugged in my absence, too. Grinders, lathe, mill, welders, table saw, jointer, etc.
There are tons of 220 volt panel/indicator lamps, one lead each to each hot.
Or you could have the 220 trip a relay sends power a 12V transform (wall wart) then from there a 12V or 24V lamp by the door ..... would let you run low voltage wires to a location where couldn't miss seeing the light.
Either of the above is done parallel to the compressor
So does one side connect to a hot leg and the other to ground?
Never. that puts current through through your ground. Verboten. A 220V lamp hooks up with one lead going to each of the wires of the 220, just like the air compressor motor. When power is going to motor, it is also going to the lamp
Those 220V Amazon specials would probably be okay, just keep the following in mind:
1) The mains voltage in China is 220V, not 240V
2) Your connecting this to MAINS, if it fails and causes problems unapproved parts might be a problem
