INDEXING HEAD, $500, Edmonton, AB
0a54c2ce-8137-4a83-8fae-d0815a735bfa
It was part of another machine - it has a connector for it.
It is probably in the 100 lbs range - I have similar dividing head for my K&T #2.
Input shaft for gears from the table feed screw, to use for doing spiral milling.
Pretty much a standard Universal Dividing Head, lots of outfits made them, and they were pretty close to the same.
This is the one I have it needs a good cleaning inside and out. I was thinking about maybe using it with the 4 th axis.
One point worth noting, is that for CNC use, you have to be prepared to lock down the spindle after each move, as there is a little inherit backlash in the worm drive that most CNC Index heads do not suffer, as they use a Harmonic or strain wave gear for the reduction, with essentially zero backlash.
True but on the other hand if I can use it with the 4th axis it would eliminate all the gear train backlash limiting any to just the dividing head.
Not sure I am following your idea of using it 'with' the fourth axis. Mind explaining?
Not really wrapping my head around how you would come out ahead, using a Universal dividing head along with a CNC rotary that is already easier and faster to operate for indexing operations.
