I have a bottom bracket on a bicycle that is seized in placed.
The thread is a left-hand thread, which tightens counterclockwise and loosens clockwise. (Just thought I would mention this.)
I have the proper tool for the spline and it sheared the female interface and also damaged the tool slightly. I tried lots of WD40 and a punch and a BIG hammer. No joy.
The axle is hardened. Drilling it out is unlikely. I may be able to cut a good chunk of it off with a Dremel. Then try to grind the remaining stub untill I can remove it. Then I can work away at the bracket case with a hacksaw. The axle seems to have a hollow internal section that is a fair bit deeper then the thread that would hold the crank arm on. This may work to my advantage. The hollow section does not go 100% thru from one side to the other.
This image is for reference. The bracket case I'm working on appears to be something other then aluminum. (Steel?)
