How to dress a diamond edge cutting wheel
OldGrinder
Hello all, I've been using a Lennox diamond edge cutting wheel for about a month, and I really like it's thin kerf and smaller spark trail.
However, it's starting to cut slower; I've been told it needs to be dressed. Can I do this by cutting into the sharpening stone I use for tools, or do I need a special ceramic stone?
Sorry - can't help on that one - BUT- welcome aboard to the Forum. Maybe someone else can answer your question
Lapidary saws all use diamond wheels . They cut a lot of very hard material, agates ,jasper and jade. . The edge will load. They clean the edge with an old piece of silicon carbide grinding wheel. That exposes the diamonds. Make sure you cool the edge. The saws use a mineral oil bath, but I have parts for a mister for my surface grinder.
The diamonds will eventually wear off the edge and the wheel will need to be replated, We used a fair number of diamond-plated tooling at Raymark and rotated them out of service for replating regularly.
A month isn’t very long, but it depends on the materials being ground and how many hours: remember, you’re only using the narrow edge.
Robin Renzetti showed using cold rolled steel or a moly dressing stick to get rid of the buildup and expose the diamond grit.
Watch the whole thing or fast forward to 11:30.
Thanks for posting the video and the time marker.
Interesting,
it makes sense, being such a fine grit they would have a tendency to plug up. I will have to look into if there is a dressing stick for my CBN grinding wheel, it seems to have lost its bite.
I have some diamond wheel which I can visually see they would need re-plating but they are really bad quality, so not worth getting done.
Interesting,
Please come back and tell us what you found. We all know how to dress a regular stone but diamond wheels are a special case. It would be good to find a procedure and a few products sources and cost.
I found out that white aluminum oxide stone 1 or 2 steps finer grit than the CBN wheel you are about to dress is adequate to deglaze your CBN wheel. They recommend to start your grinder let it get to speed and then turn it off, then slowly begin dressing the grinding wheel until it comes to a stop, repeat until you see the diamond grit exposed again. I will need my magnifier to be able to see diamonds.
KBC have the white aluminum stone and they mention that it will also deglaze diamond wheels.
I find dressing grinding wheels a very dusty, messy operations. I usually roll outside my grinding station and have a go at it. I will need to make a good dust extraction for my grinder before attempting this in my small shop or wait for the snow to clear a bit.
At first, this looked promising:
Then I read this:
Even I could come up with that advice.
I was going to suggest using a Norbide stick, but it might be cheaper to buy a new wheel:
As @fixerup noted, even Norton recommends AO to dress/true their diamond wheels:
Here is the reply from Lennox,
When a Metalmax cutting wheel, like the 1972927, slows down after several cuts, it's a sign that the wheel has become clogged with material or the cutting surface has dulled. Dressing the cutting wheel helps restore its cutting efficiency by cleaning the surface and exposing fresh cutting edges. Here's how you can dress it effectively:
Steps to Dress the Metalmax Cutting Wheel:​
Use a Dressing Stick:
A dressing stick (usually made of silicon carbide or aluminum oxide) is the most common tool to dress abrasive wheels.
Hold the dressing stick lightly against the surface of the wheel while it’s rotating. Gently apply pressure to clean and refresh the surface.
Work around the perimeter of the wheel, not just in one spot. This will help expose the fresh abrasive grains and restore cutting performance.
Check the Alignment and Balance:
Ensure that the cutting wheel is properly aligned and balanced. If the wheel isn’t running true, it can affect its cutting efficiency and cause uneven wear.
Use a Slow Speed:
If possible, reduce the cutting speed while dressing the wheel. High-speed operations might cause unnecessary heat buildup, leading to thermal damage to the wheel.
Clean the Cutting Area:
Make sure there is no build-up of metal, dust, or debris in the area where the wheel is cutting. Clogging from these materials can contribute to slower cutting.
Wipe the wheel periodically to keep it clean.
Inspect the Material Being Cut:
Sometimes, the issue could be with the material being cut. Harder or more abrasive materials can wear the wheel faster. Ensure that the workpiece is suitable for the cutting wheel.
Wheel Dressing Solutions (Optional):
In some cases, you can use a cutting wheel dressing spray or cleaning compound. These are applied to the wheel’s surface to clean out clogged particles without physically dressing it.
A cutting wheel dressing spray or cleaning compound sounds interesting, but I haven't been able to find either
One of the keys seems to be a slow speed for dressing, so an 8000 rpm angle grinder won't work. I'll have to get a bushing and mount it on a bench grinder, then figure out a way to water cool it. I have some FreezeSpray around, might try that instead, although the sharp temperature drop could shrink the metal wheel and loosen the adhesive
I just noticed that Diablo is selling 2 of their 4 1/2 in diamond edge wheels for $22 on HD, think I will get them to use while figuring out the Metal Max.
In Tool Die Shop used to use a Black Dressing Stick If I remember correctly...To dress Diamond Wheels.
Just a note in case anyone stumbles by and thinks to use a moly stick on any diamond cutting tools like the Lennox, or any woodworking grinding wheels for lathe tools...
If you try to use a moly stick on a metal fused wheel it will destroy it and remove the thin single layer of super abrasive.
A dressing stick is how you declog such abrasives.
Such as Norbide?
No.
Aluminun oxide sticks dress diamond and cbn wheels by opening up the matrix... they're soft. They declog
Norbide is very hard CBN stick made via powdered metallurgy and sintering, it is used for offhand trueing of vitreous wheels... Freehand profiling can be accomplished this way.
