Former Member
Guest
I see all sorts of posting on what we perceive materials do when being cut, well here it is under an electron microscope.
Vibration assisted machining (VAM) is a research topic. I found a paper on this with a broad survey of what people are working on. It is LONG paper. There are a lot of pictures showing many technical approaches for milling, turning, and drilling.I saw a special vibrating knife on kickstarter which is supposed to cut more cleanly and easily. Anybody see anyone applying that to machining?
.....just finish the pot of coffee, then hand feed, should be plenty of vibration...Vibration assisted machining (VAM) is a research topic. I found a paper on this with a broad survey of what people are working on. It is LONG paper. There are a lot of pictures showing many technical approaches for milling, turning, and drilling.
Review of vibration devices for vibration-assisted machining - The International Journal of Advanced Manufacturing Technology
Vibration-assisted machining (VAM) is a process in which high-frequency small amplitude vibration is applied on tool or workpiece to improve cutting performance, especially for hard and brittle materials. It has been applied to several machining processes including drilling, turning, grinding...link.springer.com
