Fine feed slipping???
thriller007
On the cx601 when i try to lower the quill with the fine feed engaged it kinda works sometimes and then other times does not. The worm and wheel look ok to me. If I hold the brass gear in my hand and turn the handle it will slip a bit but there is definitely resistance. Any ideas?
"sometimes"? As in the quill being in different states of extension? Does applying more feed eventually get it moving?
The straight cut gear on the shaft that intersects with the quill looks to be in good shape as well. And yes applying more feed generally will get the fine feed going again
I have a totally different mill but mine can slip as well. I think when you tighten the fine feed lock knob there is only a friction connection to the fine feed rather than a solid mechanical connection.
I wasn't that happy with mine either that was the main reason I went with the 4 axis dro but saying that a cheap I gauge would give you more precise readings
Yes it is just a friction fit. I did clean it up on the friction surfaces and it seems to work ok about 90 percent of the time. Possibly there is a slightly worn worm and when it hits just the right spot I have the issue.
All the smaller machines use friction clutches as far as I know. Take it apart and clean it up, then use an adhesion promoting lubricant maybe. I know that they use them for automotive, I think in differentials so maybe a heavy gear oil would be better for that exact spot.
