With the variety of talents on this forum, I thought I might post this question.
I have a 1999 Indmar inboard marine engine, essentially, a Chevy 350 in a ski boat. It is seldom used, so I have not done many oil changes. The manual states a marine oil, which is not common here (in the recommended grade of 15W40). I probably did not use marine oil in the past but someone pointed out the other day that a marine engine is always under load versus a land vehicle and marine oil is slightly different in that it accounts for that. Interesting but true? Another knowledgeable person suggested using a "High detergent diesel engine oil in the proper grade of 15W40 would be better than using a 25W40 marine oil. Taking a better look at the manual, it gets away from the "marine" designation in one paragraph but states "Synthetic oil that meets our requirements of 15W40 and API SJ/CG4 is acceptable to use after 100 hours.....". Not sure if that means that non-marine oil is acceptable if using Synthetic...
Recommended " Pennzoil Marine Oil API Service SJ/CG4 15W40 or equivalent "
Readily available options
Use 25W40 Marine oil?
Use 15W40 Diesel oil (High detergent)
Use 15W40 Synthetic?
Since I am asking questions, when is detergent oil used versus non detergent oil? I could go google but answers here are always more interesting.
