Drill grinder C$200
Drill grinder and steam boiler
C$200
High River, AB
@Tom O Need a boiler for your Steam Engine build?
I got it $150. Last used 2013 with a 75# pressure release valve.
I’ll pick it up tomorrow afternoon and he’s throwing in a unfinished injector along with it.
I picked it up and it seems to be in good condition the injector he talked about was a pump used to replenish water in the boiler but I might be able to use it for a pressure test.
I haven’t taken it out of the truck yet so more pics in a while, my Brother Bob passed away Thursday after several years with COPD surrounded by Family.
Woohoo Success!
I covered it with a old blanket and put it in the back of the truck then drove around looking for a suitable spot which turned out to be 114ave and 84st it was unloaded and opening the door was no problem mind you it wasn’t leaving I had to uncover the cage I guess it liked the windbreak after that it was gone in about 2 minutes. Way easier than I thought.
Woohoo Success!
I covered it with a old blanket and put it in the back of the truck then drove around looking for a suitable spot which turned out to be 114ave and 84st it was unloaded and opening the door was no problem mind you it wasn’t leaving I had to uncover the cage I guess it liked the windbreak after that it was gone in about 2 minutes. Way easier than I thought.View attachment 17620View attachment 17621View attachment 17622
Should’ve taken it to @YYCHM s backyard without telling him :D
