Deckel 2410 FP33 Extension / Supplementary milling machine table
Very nice DECKEL 2410 extension / supplementary milling machine table meant to be used on the FP33 milling machine.
This provides an extended work / clamping surface for large parts.
It can also be used vertically to have a vertical clamping surface.
As you can see it is in very good condition.
It is already very rare in Europe, let alone in North America !
Maybe the only one in existence here.
This is the ONLY one available for sale worldwide right now.
Initially meant for the Deckel FP33 mill but could be used on other equipment if you modify it.
Clamping surface is 1200mm x 370mm (47'' x 14-1/2'')
4 T-Slots 16mm wide (5/8'')
Weight is 187kg / 411lbs
Part Number is 2410 050001
Made in Germany as all other high end machining tooling like this.
I can provide other dimensions as required if you intend to use it in a custom setup.
This will be strapped onto a pallet and crated over for shipping.
1500$CAD OBO - open to Deckel / Emco (V13) tooling partial trades
I will ship to USA and Canada
If you are elsewhere contact me first to get a shipping rate as this is massive and heavy.
Cheers, Jason :)
